Mini power plugs
MikeK
I've got a bunch of wall warts with the mini power plugs on them.· Is there a simple way to determine whether they're 2.1mm or 2.5mm or other?·
2.1 and 2.5mm have the same outer diameter, but 2.5s have a bigger center pin.
So, you shouldn't be able to push a 2.1mm cable (F) onto a 2.5mm jack (except with a lot of force.)
** If you're certain that they're either 2.1 or 2.5 then you should be able to eye-ball the difference once you compare a few. **
Post Edited (PJ Allen) : 12/17/2005 7:32:34 PM GMT
-first find a known power socket and try it out
-second goto a radio shack and visually compare it with the nest of plugs they have find the matching letter, find the package containing the type and look on the box for the diameter info
-third use a vernier caliper
·1+1=10
Hey, you asked if there were other sizes: I have right here a pair of "coaxial DC power connectors" that I bought from RadioShack many, many moons ago -- and these are dimensioned: "5.0mm O.D., 1.6mm I.D."· I'd figure most everything out there is either 2.5 or 2.1, but like I said, anyone can make anything, and the only way to know is to know.
·1+1=10
vernier calipers are the tops! i use it daily.
i got a metric caliper at jameco for about $20.
engineer, fireman, bowler, father, WoW addict [noparse];)[/noparse]
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=47257
I've got three of their $5 (on sale) multimeters (similar to this one: http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=92020). Can't beat them for the price.
