Display problem
I am having a problem with the left most diget of my display, as you can see from the first photo all leds work OK but when I type in 301 which goes into the bottom display first then gets transfered to the top left and right displays and as you can see from the second photo it gets displayed wrong. I have gone over the wiring many many times. I unwired it and check all the leds then rewired it . I even changed the MAX7219, still no good. My program is attached any help or suggestions would be appreciated. Thanks
csavage@parallax.com
