Simple Camera/Video Streaming Software
Hello,
I'm trying to transmit my webcamera back from my robot via an onboard wireless laptop to a computer also on the network. I need a simple lightwieght piece of software that can do this. So far I have tried:
VLC
NSVTOOLS/Shoutcast
Skype
(My laptop is a PII with Windows 2000)
Any other suggestions?
-Diablo
VLC
NSVTOOLS/Shoutcast
Skype
-Diablo
Sorry for my bad english.
John R.
8 + 8 = 10
If I understand you correctly you have a laptop on your robot, that laptop is wirelessly connected to a LAN. Your robot mounted camera is connected to your laptop, and you can view images from the same laptop. If this is correct, check www.ritlabs.com/en/products/tinyweb/ for their free TinyWeb software. With this running on your laptop, you can make files,images, etc. accessable from a LAN, essentialy turning a portion of your laptop harddrive into a server which can serve up pages,images. Your web camera has to download sequential and overwriting images to a file on your harddrive, which I recall is common feature with a lot of web cams.
later, Kevin
Bad spellers of the world untie!
It works great and affordable. Download the 21 day trial.
jj
The only problem I see is that you are using a pentium 2 based laptop.· I don't know if that will be fast enough to encode streaming wmv on the fly.
Harrison
