Starting out...
I have a car project that involves either a carputer or a basic stamp. My assumption is that I need both a stamp and a developer board. I need a minimum of 3 serial ports but all the PICs I have seen only support 1. It will need to drive 2 LCD displays (or work in conjunction with another pic), accept input from the car's OBD-II port via serial, and accept an array of·both 12 and 0 volt inputs from the car.
I'm looking for a beefy stamp that can do this, and I've never dabbled in PIC's before. I don't really know what to order. Is there a beginners guide?
I think any BS2 will provide you with what you need ! Just check the User Manual for the BS (free @ parallax download area !).
You can have as many serial ports as there are I/O ports on the BS and if you choose a serial LCD, there will be no trouble to connect it ! It´s absolutely easy !!! And they even have some examples in their manual !
Best thing: The software to write the programs is free and can be downloaded @ parallax and you can even put together a more· "complex" system with just a few components on a simple board (see the Missouri-Bot pictures in my multi-cpu thread...
I would really recommend using the BS2 !!!
All the best,
Andreas
·1+1=10
It's even available at your near by Radio Shack.
http://www.radioshack.com/product/index.jsp?productId=2117994&cp=&kw=parallax&parentPage=search
www.speechchips.com
Speech & Video IC's for BasicStamps
Post Edited (KenLem) : 12/16/2005 3:30:00 PM GMT
One LCD will replace the one that came in my car's head up display. It shines on the windshield using a mirror in the dash. I'm redoing it with more information than the car originally provided. This crosses over into programming also, in order to be able to read from the car's networks. The other LCD will replace the one in the cabin that shows trip and fuel economy info. Instead I want it to also show GPS and navigating info. There will be several things going on at once being fed into the stamp.
The only thing I haven't touched yet is the car's proprietary serial format. I read that there are at least 2 serial standards I could be looking at, and it doesn't seem to be the PC standard. I haven't found anyone else who has attempted this and I don't know of anyone more equipped than I am yet so here I am asking questions :P
·1+1=10
Take a look at:
http://www.elmelectronics.com/obdindex.html
They have chips to convert various OBDII busses to RS-232
You will probably need to purchase the SAE specification J1979 to determine what codes to send to the PCM.
Some free information can be found at www.scantool.net
"OEM NMEA GPS Module" Now available on ebay for only $19.99, FREE shipping until 2006!
Product web site: http://www.allsurplus.net/Axiom/
