darlington question
If the Darlington array has 3 volts from low current logic, is it posible to control a solenoid on the other side with a different power source like 12 volts, basically use the darlington as a very low current set of relays. If not how would I do this. I am trying to use the pins that control an led matrix to go through the darlington so I can control multiple solenoids, in essence have an LED matrix but instead of leds I will have a matrix of solenoids. This is my senior thesis so I know it is hard to understand but any help will be greatly appriciated, Many thanks!
-Dan
-Dan
In the attached schematic, assume the transistor is a darlington. There is a 5 volt source driving it, but the transistor is switching (providing ground) for a 12 volt load.
And, there is about 1.4 volts across the b-e junction since there are two b-e junctions on a NPN darlington. ▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Ken
The first power source is the BasicStamp which turns the Darlington on and off.
The second power source is connect to the device [noparse][[/noparse]selinoid or motor] which is connected to the Darlington, and then the Darlington's other side is to group.
Also, at 3 watts switching, you need a discrete Darlington, the ULN2803 IC is rated for only 0.5 watts total. It will burn up.
csavage@parallax.com
·1+1=10
Also (not shown) the ground for the stamp and the other power source (12v in this case) must be tied together.
I will fix my schematic later to include this important point.
Ken
Sid Weaver
Do you have a Stamp Tester yet?
