Fried CMUcam
Hi everybody,
I was doing some demos using my CMUcam and the Basic stamp board of education. But unforunately I reversed the voltage polarities by accident
. Is there any way that I can fix it myself. And I wonder which part specificaly did I fry. Thanx for your help
![shakehead.gif](http://forums.parallax.com/images/smilies/shakehead.gif)
Tell them what you did. It shouldn't cost more than $10 or so plus shipping.
Your not the first one to do it. I got lucky and just fried the voltage regulator. In fact, see if the regulator is still putting out 5v, first
·1+1=10
· Please use rectifier diodes (1N4001, 1N4002, &c.)·
· [noparse][[/noparse] But it only works when the supply always runs through it. ]
· Drawing attached.
You can just put a diode on the ground side to prevent reverse voltage. That saves you one of the .7 volt drops.
The slick way to do it is to use a PNP FET with the drain to positive battery, the gate to negative battery, and the source to the regulator. Almost no voltage drop. and the FET won't pass any current if there is a positive voltage on what should be the battery ground
Happy New Year. I went back to my CMU cam 1 and i checked the regulator and it looks fine to me. The output voltage was 5v and the input was 6.6v. I think the faulty part is the micro controller the sx28ac as The red LED is on but the green LED is always off and when i programed it doesn't respond. I wonder if i can reprogram the sx28ac or do i have to buy a new one?!. Once again guys Happy New Year and hope all your wishes come true in 2006.
So far as the "reverse diode as a high-current reverse-current path·and blow the fuse" idea goes -- wall-warts don't have fuses and batteries don't like run-away current that way either.·
Nobody is really interested in any of these "solutions" anyway, it's always with the·live without a net stuff because fuses are 3 for $1 and that's too much money.· All most anybody wants to know is·how to set the "power protection bit" on their STAMP.
csavage@parallax.com
