Improved Search Engine Available For Parallax Forums & Website
Hello Everyone,
·· For those having trouble with the forum search engine we can offer an alternative search engine which is a little easier, if not more familiar, and yields much better results.· At the link below you will find our Google Search engine, which will by default·search the entire Parallax Website, as well as the forums, with a few limitations.· The limitations mean the new search engine·may not find all of the information available in the forums, but will certainly make it easier.· You can access the new search engine at the link below:
http://search.parallax.com
To restrict a search to the forums, you can go into the Advanced Search options and specify a domain name, for example, forums.parallax.com or you can simply enter a search such as the one below looking for information on the DS1302.
DS1302 site:forums.parallax.com·····
This will search for all occurrences of DS1302 within the forums only.· You can also use + and - to narrow your search results.· For example, the following line does the same thing, but only brings up results that do NOT contain the word battery.· We hope this makes searching threads in the forums less painful.
DS1302 -battery site:forums.parallax.com
csavage@parallax.com
1. Go to http://search.parallax.com
2. Click on Advanced Search
3. In the "with all of the words" field put the words you're looking for (can be found in any order)
4. In the "with the exact phrase" field puta phrase (words in specific order) that you want to find
5. Set Domains to Only and put this in the "domain field": forums.parallax.com
Now click Google Search.· Note: You can use steps 3 and 4 together or separately.· Here's an example screen shot:
Jon Williams
site:forums.parallax.com search terms
Replace search terms with what you are looking for.
Is there any way that this search format could be stuffed into the forums search box?
Jim
Parallax IT Dept.
Can you guys update the Google Advanced search to give a pulldown menu for the domain box? Thanks.
Jim
Parallax IT Dept.
Kevin Horton
Ottawa, Canada
I'm really NOT a professional adver-Teaser. But this product is very very good.
If the new search-engine is not satisfying again,
take a look into
www.dtsearch.com/
This is the state of the art about speed and search-possabilities.
If you don't want to use it for websites. Use it for your internal data!
best regards
Stefan
