50Hz Operation
I want to take my basic stamp & power supply overseas but don't know if the power supply will work with 120VAC @ 50Hz. I don't intend to use the power supply at anywhere near its limit. Will it be OK?
Otherwise, I believe a 60 Hz transformer run at 50 Hz will still work -- it might run a little hotter, but the BS2 doesn't normally 'stress' any wall-wart I've ever seen. This means, normally the wall-wart at 60 Hz doesn't get warm at all. At 50 Hz it might get a little warm.
John R.
8 + 8 = 10
·1+1=10
