Reset stamp with code?
Is there a way to force a reset on a BS2P-40·using code?
I was thinking that if you had a number of inputs or outputs that were in an unreasonable state, it
would be nice to be able to force a reset.
If not, I could just make a seperate logic circuit that monitored the signals for a reset.
thanks for info
Bruce King
thanks for info
Bruce King
·· You can reset the BASIC Stamp using an I/O pin without a problem.· But, you must make sure the I/O pin tied to the reset line is always in an INPUT state until you you're ready to do a RESET.· Then, to RESET you simply make that pin LOW.· The instant the Stamp Module resets it will make that I/O pin an INPUT again.· The point is, you never want to drive the line HIGH.
csavage@parallax.com
