Question.About the RS232 in the BS Super Carrier.
Hello.
Now I want to connect the Super Carrier with the PC.Everybady know that the RS232 have 9 Pins,but now I can confirm:when I connect it, the·"2·Pin" of the RS232 in Super Carrier must connect with "2 Pin" of PC' RS232 or "3 Pin" ?
Thank you !
Thank you !
You are good.
· If you're talking to the BASIC Stamp (Or Programming it) through the programming port, then you should be using a standard straight-through serial cable.· This means each pin will connect to the same number pin on the other side.· Cables with pin 2 to 3, etc. or cross-over cables, serial link cables or null-modem cables won't work.· Now, on the other hand, if you are using general Stamp I/O pins to communicate, then you will have to do things a bit different.
BTW, this is actually a duplicate thread...I removed the copy, but please try not to post the same question more than once in the forums.· Thanks.
csavage@parallax.com
You know I am from China.So my English is not good. I am sorry that I can't browser many topics, because it's difficult.
I will do better next time.
Can you introduce me some ?
