RFID Reader Frequency ?
I am considering using the Parallax RFID Reader. www.parallax.com/detail.asp?product_id=28140
According to the .pdf document, this unit operates at 170 KHZ. Is this correct? From my limited research, it seems that most low frequency readers operate at 125 Khz.
The most significant is that the reader is compatible with any of the various EM-410x tags. These are nominally "125 kHz", but vary from 100 to at least 150, and Paralax is not the only refernece I've seen at 170 kHz. I have used tags that are both EM4100 and EM4102. I am also under the impression that EM4105 will also work.
I am not going to claim to be an "expert" in RFID, I've just recently been (and am still going further down) this road.
John R.
8 + 8 = 10
Well that is encouraging at least. I would like to use a 30mm round tag, or smaller. I don't know what EM-410x tages are (but I will be Googling soon). Most of the tags I looked at specs on, were 125 KHZ +- 10%. That would certainly not include 170 KHZ.
Thanks for your help John.
In the docs for the reader, it also references the 125kHz frequency. I've got stuff (including notes) packed away, but I remember reading more in the range of 140kHz with a frequency reading on my hand held DMM.
I've used tags from Parallax, Phidigits and an OEM (purchased from a "third party") with success.
John R.
8 + 8 = 10
www.sokymat-usa.com/DataSheets/WORLD%20TAG%20Unique%20-%2050%20mm%20-%20V4.pdf
Greetings from Germany,
G
In general, there are the HDX (Half Duplex) readers / transponders wich work on a single frequency, for instance on 125KHz, and there are the FDX-B (Full Duplex) readers / transponders wich work on two frequencies, for instance 125KHz AND 134KHz. More frequencies are possible, but let's not add more confusion to this subject. AFAIK, HDX and FDX-B are not compatible. So,··for instance,·a pets tag (FDX-B) can not be read with a HDX reader (the Parallax kind). So, back to the quote, "... any other HDX 125KHz tag should also be ok."
·I asume you allready knew this, but others might not be aware of this. They could purchase readers or tags (HDX with FDX-B mixed) and get disappointed by the results.
That goes for me too
Best regards,
Ed.
A horse is a horse, of course of course...
Post Edited (Mr.Ed) : 12/12/2005 2:56:11 PM GMT
thanks for clearing this up - you are absolutely right, the Parallax RFID reader can only deal with HDX transponders on a single 125kHz frequency.
G
