Problem with an A/D COVERTER
Hi
I'm connecting an Ir SHARP distance sensor ( GP2D120 ) to my basic stamp 2 with an 8-bit A/D converter ( ADC0816 ). But I have a little problem. I don't know which pin of the A/D converter ADC0816 has to be connecetd to the basic stamp 2 ( the output of the A/D converter, the digital· 8-bit output ) because it has 8 output pins instead of one. I'm lost and I would like someone to help me. For more information about the ADC0816, you can see the datasheet by going to this link :
http://thayer.dartmouth.edu/~engs031/databook/adc0816.pdf
Post Edited (Hills) : 12/11/2005 8:17:13 PM GMT
Although I didn't go into your problem in depth, it appears that you're using an ADC with a PARALLEL output rather then one with a SERIAL output. To use the unit you've got, you will need to read all 8 output pins, to access the incoming data. It can be done, but it's hardly worth the waste of pin ports.
A much better choice woiuld be an ADC with a SERIAL output, such as this one from National Semiconductor:
http://www.national.com/pf/DC/ADC0831.html
With that or any similar ADC with a synchronous serial output, you only need to use the SHIFTIN command to access the data serially, using far fewer pins.
Bruce Bates
