Bs2p and 555 timer
Hello,
I'm using basic stamp to do aerial photography.
I would like to write a little applet to switch a relay on every 2 seconds. (This relay drives a photo camera).
I will use Bs2p and 555 timer.
I'm new to Bstamp. So I'm searching for·a sample of interface between Bstamp and 555 timer (wiring diagram) and sample code.
Thanks for your help.
Mario
Mario
I looked up "relay" using the Site's search and found this drawing:
Post Edited (PJ Allen) : 12/10/2005 10:27:06 PM GMT
Aerial photography from what???
If you are in a big plane, all you need is the 555, and turn on the power via switch to activate.
If a RC plane or rocket, you need some way to activate the 555 ( RF control, or altimiter ) to turn on the 555.
A (P)rogramable (U)nijunction (T)ransistor (PUT) will also work in place of a 555 ic.
Using a stamp will work, but would take up space, and weight if both are critical...
Bob N9LVU
http://forums.parallax.com/showthread.php?p=561786
csavage@parallax.com
