Electronic Trumpet
I am trying to make a trumpet using the BS2 module. I would like to add midi out in the future, but for now all I want is to use simple audio out such as FREQOUT. I don't understand how to play the note only when it is supposed to be on. I attached my source that I have so far (no sound yet), and a list of the notes with their corresponding midi number, frequency, and register.
Any hints, sample code, or ideas are greatly appreciated,
Matt
Matt
How do I make FREQOUT's duration dependent on a button combination and then change with the combination?
Are there other ways to produce frequencies with code?
Matt
·1+1=10
If there were a way to stop FREQOUT when a new combination of buttons were pressed and start a new FREQOUT, then I could settle for a predefined duration. I would also need FREQOUT to stop as needed (if silence is needed before the predefined duration)
·1+1=10
Any idea how to implement (or even find) such a midi ic?
·1+1=10
I think a possibility for the midi audio out is usig a pda. I guess I'll be looking into this.
·1+1=10
I hope this project is more possible than it seems.
·1+1=10
From the BS2 code comments:
'The first pair raises and lowers the register.
' The second pair raises and lowers the octave.
Also (since I dont play trumpet) I dont see how with 3 buttons and a register (and octave button) you can get a full set of notes.
thanks
The same notes may be produced from the different key combinations without changing the register (ex: v1 + v2 = v3).
The registers do overlap the higher the note is. This overlap also causes there to be different valve combinations for the same note.
I hope that explains it well, otherwise the registers and notes are outlined in the notes.txt attachment in the first post. The register overlap isn't evident until beyond halfway down.
