Thremopiles and Pyroelectrics
LoopyByteloose
Can anyone explain the differences in simple terms.
From what I read, I believe that thermopile generates a·DC voltage in realationship to temperature.
And the pyroelectrics generate an AC voltage in relationship to temperature when you have an aperture opening and closing at a regular rate.· It seems they usually have a spinning wheel·with appropriate holes placed in front of them.
I was hoping that I could use the pyroelectrics as a replacement to thermopiles in Jens' flight controller, but it seems like I need to provide a lot of extra hardware.
thermopile -- A group of thermocouples connected in series-aiding. Specifically:
Thermopiles are used for the measurement of heat where thermometers cannot be employed.
pyroelectric material -- A material which produces electrical output when subject to a change in temperature
pyroelectric effect -- Also called pyroelectricity. The redistribution of the charge in a crystal that has been heated. The crystal is left with a net electric dipole moment - i.e., the centers of the positive and negative charges are separated.
pyrometer --
Thanks, but I have been search and reading quite a bit about the Pyroelectrics being IR motion detectors that are used in security.
The dictionary really doesn't get me into enough detail for applications.
We are talking about two very distinct deviews. One measures temperature in the IR spectrum, the other measures movement [noparse][[/noparse]of warm bodies]. Both seem to be really interesting
I have two PIR or Pyroelctrics here that are rated as 30meters distance and will view motion from left to right as different from right to left [noparse][[/noparse]or up to down versuse down to up]. Someone wanted to have something like them on a bot that could chase his dog. It seems feasible and I would love to have my Toddler exhibit such behavior - uncanny. These seem better suited for watching your front lawn and backyard.
On the other hand, I still want to buy some Thermopiles, but I cannot locate another outlet aside from Digikey. Does anyoone have suggestions? Digikey wants $16USD each for the little guys.
