Boe Bot Tank Tread Kit — Parallax Forums
pebladespeblades Posts: 14
edited 2005-12-12 20:55 in Robotics
Hello;
Will the Boe Bot Tank Thread Kit work with the Boe Bot Digital Encoder Kit on the Bot Bot Robot kit. Thanks·
    edited 2005-12-09 19:32
    Hello,
    ·· Not without some serious modification, since it relies on the holes in the standard full-size wheels to work properly.· You could use a similar set up to read the holes in the Tank Tread gear-wheels though I suppose.
    csavage@parallax.com
  • pebladespeblades Posts: 14
    edited 2005-12-09 20:08
    I had wondered if it was possible to read the holes in the tank tread gear-wheels. Thanks.
    edited 2005-12-10 01:11
    It would be tricky...But if you're clever·it could be done.
  • WhelzornWhelzorn Posts: 256
    edited 2005-12-10 23:19
    what if you tried to read the holes in the tread itself? I figure it would work better than the gear-wheels, which are orange and might reflect too much light to get accurate readings.
    edited 2005-12-12 15:45
    I see a orange gear and I want to paint it black [noparse]:)[/noparse]
    ·1+1=10
  • Tricky NekroTricky Nekro Posts: 218
    You could just find a way to fix a wheel like cut paper ,painted black and with in some order, on the back of the front "wheel"...
    P.S. I can see that Paul Baker is a fan of Rolling Stones... Me too..smile.gif
    Provas, GReece
    -Rule your Destiny-
    --Be Good. Be Bad. Be Provas--
