Does inkjet ink resist PCB etchant?
Hi All,
I just got one of the serial printer kits. My intention is to make a 'bot that imitates the patterns of ancient flatworms. However, I got to wondering, if inkjet ink will resist PCB etchant, then I could make a PCB machine out of it. Would beat the you know what out of toner transfer. Anyone know if it does indeed resist?
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
Jonathan
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Those that would give up freedom for security will have neither.
But xerox/laser toner DOES hold up to etchant.
Dot maxtix is just that, a bunch of tiny little dots, it will not SEAL the part that is covered with ink, instead there will be a bunch of tiny holes. But I am not too sure if thats a big enough deal to mention. Try it but don't be surprised if the dotmatrix ink etches are very shoddy. Laser printers seem to do better at fine detail too.
Also, I am not sure that you CAN transfer the dot matrix ink from your printed medium onto your etchable board. The benefit with laser toner, is you can prink your mask onto a transparency, then using an iron, you RE-MELT the laser toner onto your etch board.
Dot matrix ink doesn't use HEAT to work. (making the transfer from your transparency to your etch board almost impossible) This might be why laser printers work best.
BPM, I'm not trying to transfer the ink. I'll be printing directly onto the PCB. Since this will be a custom application, I can cover/re-cover an area until it is covered enough to etch.
Here is hoping!!
Jonathan
Using UV inkjet ink may prove to be a better solution (pun), since it uses UV to cure the ink and isnt·air drying (evaporative), it should produce better results.
·1+1=10
Post Edited (Paul Baker) : 12/9/2005 7:37:48 PM GMT
Also note that the standard ink is intended to be used on "porous" materials.
You may also have problems (depending on the type of "ink") in that an inkjet line is a series of "dots" (as mentioned above) that are actually microdroplets of ink. If these flow together as they dry, or overlap, you would have a "solid" line, other wise you might end up with a very fine "mesh".
John R.
8 + 8 = 10
Post Edited (John R.) : 12/9/2005 9:38:39 PM GMT
Beau Schwabe
IC Layout Engineer
Simply print directly to a photo sensitive board. ( Printing must be done in the dark of course )
This way you eliminate the step requiring a transparency with the photo resist.
Beau Schwabe
IC Layout Engineer
True, a sharpie does resist ehcting, but not that great. At least not with the method of etching that I use.
Knight.
This message transmitted with 100% recycled electrons.
Gravity doesn't exist. The Earth sucks.
Make a man a fire, and he will be warm for the night.
Light the man on fire, and he will be warm for the rest of his life.
I print a positive image onto to a clear transparency file WITH AN INK JET PRINTER.
I carefully let it dry and then use this with a light sensitive printed circuit board.
I seem to get much higher quality this way.
I can also save an image for multiple use and I can easily inspect an image for flaws and touch up.
Building a whole machine for this is a bit over the top.
I think that you would be better off to build a machine that could easily keep the drilling of the holes to a 0.1" grid.
If you used a X-Y table and steppers with a small PC camera to 'see' the drill site, you could then hit a button and have the hole drilled.
I now do all my holes by hand with a pin vise holding a 0.8mm drill. I have much better control that with a Dremel tool running at full speed. But it remains a bit tedious work.
So, you see that this seems to be my biggest problem with making one off or prototype circuit boards - not the etching process.
Well, I couldn't get the printer to work yesterday. It may have a problem or it might be me :-0. I hope to get this resolved soon. I doubt it's going to work, but I'm the type that the idea will bother me until I know one way or the other. Doing it is the easiest way to flush it out of my system
Kramer, I too get a little sick of the toner transfer method. Some days it is simply great, other days I pull my hair out in chunks. I don't mind the drilling so much, but the transfer can drive me nuts. I make PCBs pretty often, so I want to get a system which is reliable but I just can't afford to go the CNC route. So you like the photo method? I haven't tried that for close to 20 years, maybe it's time I gave it another shot. Any helpful hints?
Knight, I find that the resist abilities of a Sharpie pen depend on the temp. of the etchant bath. Too hot and it doesn't work well, but in the right range it is fine.
Beau, interesting idea to try a photo sensitive board and print directly. I may well try that too.
Thanks for all the input.
Jonathan
How are you planing to print directly on PCB??
Post Edited (Orion) : 12/10/2005 4:38:56 PM GMT
Nice looking boards. How well can you do traces between .01 spaced pins? That is really what I would like to be able to do reliably. Touching up inbetween pins is a toughie.
I hope to print directly onto the PCB using Parallax's new serial printer module. It probably won't work, but that never stopped me from trying before!
Jonathan
Post Edited (Orion) : 12/10/2005 5:02:43 PM GMT
