Need advice - Using a microphone for audio detection
Hello guys,
I have a project where I want to take a custom designed robot head and give it sight, speech and audio. Right now, the challenge is the audio. I did a search on the Parallax forums and the closest thing that came up was an electric guitar tuner but it is more advanced than what I need. All I want to accomplish is for the stamp to do something if it hears audio on the left side or audio on the right side. For example, if I clap my hands on the left side, I would want the head servo move to the left.
Here's a circuit I found from a link Paul Baker provided in that guitar forum. Would this circuit work?
····· · vcc
······· · O
········ ·\· EQUAL TO REQUIRED IMPEANCE
········ ·/· EX.= 1000 Ohm
········· |···· CAPACITOR MOST ANY VALUE 10uF 16v
|·· |---0----| (
·· AUDIO OUT
|·· |---O
Here is the one I want to get from Radioshack:
Here are some quick specs:
This omnidirectional microphone element has a wide 30-15,000Hz frequency response. Requires 4-10VDC.
Here·are·the images of the ·bot head I am designing, that the two microphones will mount to.
Thanks for any help at all.
Post Edited (SN96) : 12/9/2005 12:47:27 AM GMT
····· · vcc
······· · O
|·· |---0----| (
·· AUDIO OUT
|·· |---O
- Omnidirectional condenser microphone
- Wide 30-15,000Hz frequency response
- Electret Microphone Element with Leads
I put this kit together at one time (see link):
electronickits.com/kit/complete/elec/ck1607.htm
Post Edited (Lightfoot) : 12/9/2005 1:49:26 AM GMT
microphone circuit -> op/amp -> diode -> cap -> input pin
Connect the + lead of the cap to the diode (forward biased), and the - lead of the cap to ground.
When a sound is detected it will be amplified and "charge-up" the cap through the diode, when it reaches 1.4V, then the stamp can detect that the pin is high. After detection make the pin LOW for a millisecond or two to discharge the cap. Then make the pin an input again, and your ready to detect the next sound.
Should work...
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Those that would give up freedom for security will have neither.
Just to clarify that I understand you, the circuit I need to design is like this?
····· vcc
······· · O
|---|·· |···· +···························· Diode··Cap
|·· |---0----| (
·OPAMP
<|----|(----o>>>·to stamp I/O pin
|·· |---O
·········GND
What pin # should the mic connect to on the OPAMP? If I am way off base, could you type the proper circuit if it is not to much trouble?
You can use the opamp as inverting or non-inverting it doesn't matter. Inverting configuration is more common.
You will have to mess around with the gain to find a good value.
For the opamp, you will probably have to bias the "+" input to 1/2 the supply voltage (2 10K resistors).
Then run the mic input through a 10K to the "-" input, and also connect the "-" input through a 100K to the output.
That will set the gain at about 10 again you might have to adjust the 100K value to get good results.
Do a google search for audio opamp circuits and you should find several that will work.
Bean.
Post Edited (Bean (Hitt Consulting)) : 12/9/2005 3:10:12 AM GMT
Steve
I am going to buy the parts and bread board test this circuit. One more question though, do I make this circuit for each mic I plan to use(two seperate circuits)? I want to·use 2 mics, one for the left side, and one for the right side. Or do I use the same Op AMP, but just connect the mic(s) one to the - input and one to the + input?
I am going to try the LM741 Op AMP.
Thanks!
