DS1302 question
Is there an easy way to be able to flash a led at 1 second interval, and still maintain clock integrety....Any help would be appreciated...
Thanks in advance
Guido
Thanks in advance
Guido
http://forums.parallax.com/showthread.php?p=552892
csavage@parallax.com
http://forums.parallax.com/showthread.php?p=553075
·· There is no pause...Did you look at the program I refered you to?· It sits in a loop checking the time until the seconds change, then it updates the displays when the seconds change.· There are no PAUSE commands in the routine.
Thank You, I did look at it and found what you were talking about. I am Sorry I did not get back to you sooner, but like I have said several times I am a dangerous beginner and have been real busy at work...
One more question reagrding the DS1302, If I supply external battery to pin 8 and ground will this keep the timing chip up and running during power outage?
Guido
·· Yes, it will keep the clock running and the RAM backed-up.· The battery should be around 3V or so.· That way it will only be on when the main power is lost.
Also, to flash an LED with the seconds, and still do aother routines, I would simply put the following in a the routine after getting the seconds from the ds1302 ...
if seconds.bit0 = 0 then low led
if seconds.bit0 = 1 then high led
Hope this helps...
