BS2 with extra memory
I am doing a simple project related to EEPROM memory storage with my BS2.
I can see that Parallax stop selling X25640.
Since I lived in Jakarta, Indonesia, I couldn't find this XICOR IC.
Does anyone know any alternative solutions beside using I2C EEPROM IC?
Bronson
Bronson
http://www.parallax.com/detail.asp?product_id=602-00013
csavage@parallax.com
Thanks for your prompt reply.
But 24LC128 is for BS2P or BS2SX, not for BS2.
If possible, I need some IC like X25640 due to simple connection and I don't have BS2P or BS2SX.
Do you have any substitution ICs of X25640? 4K capacity is enough.
Also, if I need to find this info on Web search engine, what is the keyword? SPI serial EEPROM, 2-wires serial EEPROM, or 3-wires serial EEPROM?
What do '2-wires' and '3-wires' terms refer to? Does it mean I2C connection?
Bronson
I thought that 24LC128 only works with BS2PE and BS2SX as stated in
So, what is the difference between SPI serial EEPROM, 2-wires serial EEPROM, and 3-wires serial EEPROM?
Thanks guys...You are the best.
It looks like you are writing your own text here, as this is what the web site actually says for that product:
"DESCRIPTION: This is the recommended EEPROM when you're implementing an OEM BASIC Stamp 2SX or BASIC Stamp 2P design."
You introduced the word "only", which never appears in that text.
As far as the different types of synchronous serial interfaces (SSI), each has it's own inventor/promoter, and proprietary name. Some of the names are SPI (Motorola), Microwire (National), Maxim 3-wire (Maxim/Dallas) and lastly I2C (Philips), where the latter is the most advanced of the protocals. There may be others as well, but those are generally viewed as the most common ones.
Here is a web page with some more general information on SSI's, and how they're accessed:
http://www.epanorama.net/links/serialbus.html
Bruce Bates
The BS2SX and BS2P have I2C commands built in. The BS2 can do I2C but you must code the protocol (which isn't too hard).
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Those that would give up freedom for security will have neither.
