Children's Church "Press Your Luck" or "Whammy Board" HELP
Hello. My name is Darin Roberts, and I am the
Children's Pastor at Lighthouse Assembly of God in Melbourne Florida.
···· I had a friend build a random display board (like in the game show "Press Your Luck" aka "Whammy") for our childrens church.· He used your basic stamp (the board says "Board of Education" and at the top says Rev B.·and the stamp says BS2SX)··to create random #s going from 0 to 31, which would make lights randomly bounce around on a 6 by 6 point board (the center 4 boxes are under the Children's Church logo so are inactive - making 32 boxes).· Each box had 8 LEDs around it.· The boys or girls would push an activator button to start the sequence, then push it again to have it stop.· Unfortunately, the builder never got more than 16 of the channels to work, so we sped up the random timer to jump about 4 times a second, making it hard to track so you were never sure that some were inactive.· In the 6 months we used it, we never got this bug worked out.·I have since moved to florida, and in the move, all the bouncing made the component board which hooks your board to the LEDs come unbound.· So I now have a cool parallax basic stamp board, a lot of LEDs, lots of little wires hooked to a lot of resistors, and no board for my ministry.
I contacted tech support today (12-7-05) and they advised me about getting a··DB9 serial cable, plus the links to the 504 page book and the software needed to repair it, but I have no idea what to do next.
I appologize for all of this.· My training is in child psychology and
theology, and my grasp of electronics is very basic, but I am trying to
learn.· Please e-mail at kidpreacher@hotmail.com, or call me at 321-806-9156.
Darin Roberts
www.kidpreacher.org
Darin Roberts
www.kidpreacher.org
·1+1=10
I am not able to contact the builder anymore, so I think I will have to start over.·
Though I can not read a schematic by symbols,·I do know how to solder, if someone says to put a jumper from wire b to resistor A, or from the long side of an·LED to ground.· I also have a man in the church who says he can help me build something if he has a schematic to follow.
As to the hardware attached to the BS board, there are 5 chips attached to the project board allong with 32 resistors.· 2 - CD4067BE and 4 - N2803AZ.·
I hope this helps.
Darin Roberts
WWW.kidpreacher.org
·1+1=10
Thank you again
Darin
·1+1=10
The ULN2803 and the LED connections are not important. There is only one way those should be connected.
·1+1=10
If you can do it, I get great pictures by putting my pc boards on a scanner and scanning them.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Those that would give up freedom for security will have neither.
I'll see what I can do to decifer the setup. I don't think you'll need any new components, but it may come to ripping out all of the wires for the CD4067BE and rewiring them.
What chip is in the lower right hand side of scan.jpg, Also above that appears to be an empty socket, did a chip fall out, do you still have it? Is it the same as the chip below it?
·1+1=10
I will also be happy to rewire this from scratch if it will make all 32 channels work
I truly appreciate this
Darin
·1+1=10
Darin
P4 P5··· Action
0·· 0···· Both CD4067s are active, but both are outputing a 0 which doesn't turn on any LEDs
1·· 0···· Bottom CD4067 is inactive the output of the top CD4067 is on according to the value on A,B,C,D
0·· 1·····Top CD4067 is inactive the output of the bottom CD4067 is on according to the value on A,B,C,D
1·· 1···· Both CD4067s are inactive -> no LEDs lit
I can give tips on how the darlingtons are connected when I am at a computer that can read pdfs (tomorrow).
·1+1=10
This completes the circuit connections. Now you are ready to program.
·1+1=10
http://www.st.com/stonline/books/pdf/docs/1536.pdf
Pin 10 (Common Free Wheeling Diodes) does not to be connected because you are not driving an inductive loads, If you want peace of mind connect it to Vdd (+5V).
·1+1=10
Darin
