BS2 - Hyperterminal?
I need to be able to input info from a PC to a BS2 while the BS2 is running a program.
Can Hyperterminal input serin data to a running basic stamp? And if so, how do you send it?
If not, is there an easier way to do it.
I appreciate any help you can give.
Thanks, Lou
Thanks, Lou
Sid Weaver
Do you have a Stamp Tester yet?
What about the info. If I have,"SERIN 16,baud19200,[noparse][[/noparse]c,d]". Then do I only have to put, 20,50 to give the values of c and d? And then press enter?
I'm afraid I haven't found anything on typical transfer of data for the hyperterminal.
Also if anyone know of anything better than hyperterminal to use?
Thanks again, Lou
Sid
An aside, Minicom under Linux can do everything HyperTerm can do... There is small live floppy distro that setup to be a serial console for other machines that you may want to look into.
