Analog signals
···· I'm new to the Basic Stamp and some of this programming in general.· I have a project that I want to have two analog signals control a servo valve.· Any ideas on what type of setup I should use?
At the risk of jumping in with only minimal information, I'd suggest an LTC1298 chip which will give you 2 12-bit analog ins and is easy to interface to the stamp. Then, an LTC1452 (might have to check that number!) will give you an easy DAC with a voltage output.
Cheers
