ap-8 and bs2
We are currently trying to use the BS2 to control the ap-8 audio player. I load the code into the software and execute it, and the debug screen comes up, however there seems to be no output what so ever to the ap-8.· We have the red black white cable plugged into the X5 spot on the bs2 REV B board, and into the serial part of the AP8.
the code i am using is the sample code off of your website.
thanks for any help you can give us.
1) Does the AP-8 have power? Is the power switch on?
2) Are you connecting to the SER header on the AP-8? Is the polarity correct on the connector correct (on the AP-8, black is near the edge of the pcb)
3) Do you have the correct baud rate setting for the AP-8 baud jumper selection?
4) Do you have toe correct address for the AP-8 address jumpers selection?
Jon Williams
I was not sure if the address was the "X5" on the rev b board, or if you used the 15, 14, 13, or 12 exactly; this might not be the correct idea at all .
the baud rate is something i am not sure about. Do you think you could give me a little more detail about it?
should it be the typical 9600? or is it supposed to be something different?
Jon Williams
Jon Williams
Post Edited (Jon Williams (Parallax)) : 12/6/2005 3:47:10 PM GMT
