How to Wire a BS2
I was looking at the schematic for the BS2, and had a few questions.
Does anything need to be attached to "ATN"?
What needs to be connected to "RES"?
Do both "VSS"'s need to be connected?
Does ground connect to "VDD"?
What connects to "VIN"?
Can "SIN" and "SOUT" float? If not, what circut needs to be attached to it? A 10K pull-down or pull-up?
What are the minimum connections that need to be made in order to use the BS2 on a breadboard (not counting IO pins)? I am not intrested in programming it here, just running it temporarily. It can be provided with either 9 volt power or 5 volt regulated power.
Thanks!
Borgel
Thanks!
Borgel
Sid Weaver
Do you have a Stamp Tester yet?
csavage@parallax.com
Post Edited (Chris Savage (Parallax)) : 12/4/2005 10:17:49 PM GMT
If you're driving Vin with a 5.5 to 15 volt signal, you leave Vdd open, as that is the output of the on-module voltage regulator. You NEVER connect it to ground.
If you're driving Vdd to +5 with an external regulator, I believe you leave Vin open. Apparently this has no bad effects on the on-module voltage regulator.
You NEVER drive Vdd with anything over 5 volts, as that could cause damage. Driving Vin with less than 5.5 volts may lead to brown-outs on the BS2, but shouldn't permanently break anything.
The Pre-programmed PIC is $11.00 (http://www.parallax.com/detail.asp?product_id=PBASIC2C/P)
The EEPROM is $5.00 (http://www.parallax.com/detail.asp?product_id=602-00001)
The Resonator is $2.48 (http://www.parallax.com/detail.asp?product_id=250-02060)
If your program was already loaded on the EEPROM, these are the only components you need!
Thanks for all the responses, but could someone clarify the two conflicting posts about Vdd? (Not to offend anyone, of course)
Borgel
