CCD or CMOS camera and BasicStamp
Hi all,
I'm a newbie to the BasicStamp world and was hoping somebody could answer a question for me.
I am working on a project which needs to take a digital image every 15 minutes and store that on board for later transmission over a modem.· The image doesn't need to be very high resolution (320x240x256 shades of gray would be more than enough).· The BasicStamp has everything I need the processor, real time clock, modem, etc.· I just haven't been able to locate any info on the CCD or CMOS camera.
Anybody know of any projects which have used these chips?
Bernie Blakeney
Bernie Blakeney
And the BS2 has 2K of EEPROM for your program, and 26 bytes of RAM. As a controller, it's outstandingly easy to apply. As a digital image storage device, it would not work well. If it can 'stand to one side' of the data flow, it can easily act as a process controller, though.
Rafael
Using DTMF you have numbers 0 through 9
You could use numbers 0 through 7 to represent 3 bits at a time
(76,800 * 8) / 3 = 204,800 Tones to send
I dont know how fast you can send tones but even if you could send at a rate of say 10 per second one picture would take 5.68 hours to send.
Convert the image to 9 level of grey using DTMF 1 through 9 to represent levels to send in 2 hours
compress image variaous mehods perhaps 1 hour send time
Think outside the BOX!
Probably halve the time, right?
Rafael
