Main and Aux IO - conditional loop
Is there a was way to do something like:
Or will I have to seperate the processes like:
I'd like to not to have to do something like the latter.
I am using a BS2P.
My ultimate goal is to monitor several I/O pins at (mearly) the same time. Then go into a subroutine to time how long the pin is high. When the pin goes low again then return to the main loop.
I am pitiful at good programming technique, so if you need to get too advanced to do this, be gentle. I can get it, but I may be a little (a lot) slow in comprehension.
Thanks!
Freeing smoke from wire and IC captivity since 1972
<!-- Edit -->
DO WHILE (IOTERM 0 IN8 = 1: IOTERM 1 IN0 = 1)
IOTERM 0 DO WHILE (IN8 = 1) IOTERM 1 DO WHILE (IN0 = 1) XXXXXXXXXX LOOP LOOP
I am using a BS2P.
Thanks!
<!-- Edit -->
Can polling be done with both Main and Aux i/o's at the same time?
<!-- Edit -->
· oldState = INA
· DO WHILE (INA = oldState)
Jon Williams
Supposing it is not possible to move your i/o pins to one bank, your program alternative is workable. Your DO:LOOP code seems a little unweildy. I'd do something like this, using a RAM variable to "shadow" the value on the auxio pins:
That will jump out of the DO:LOOP when either one of the pins goes to 1. I just like to keep the logical conditions concentrated in one place. Note that AUXIO is equivalent to IOTERM 1, and MAINIO == IOTERM 0.
Question: How long are durations of the events you need to time on the pins, and to what accuracy do you need to time them? Also, is it possible that events occur simultaneously on more than one pin?
It is possible to do this with POLLing, too, as you surmised. The BS2p handles polling on MAINIO and AUXIO simultaneously. That is, even if MAINIO is selected, the Stamp will respond to POLLing events that have been set up previously on either main or aux io.
It needs to be set up and then activated with a POLLRUN and/or POLLWAIT so that a change to a target state on any of your selected pins would immediately branch to the timing code.
That is the essence of it. The devil will be in the details, of course!
Tracy Allen
www.emesystems.com
Polling is a faster execution time (IIRC), so maybe that's the way to go. How do I set up the Stamp to poll the aux pins?
Only one pin at a time will be high.
Exact time is not really needed. Only cumulative a cumulitive count comapred to a known value.
I am going to give some more details, as I know it is hard to help when the full picture is not known. I am sorry for not doing to earlier.
I am monitoring several solenoid valves.·Each valve, when opened, will let out fluid from·its own container. I am planning to monitor to amount of fluid released and when approx. 75% of the fluid has been released, I plan for an LED to light up. I am going to conduct several trials to get a mean count for the time required to drain the container. From that i will derive the 75% mark.
As a pin goes high (signalling that the soleniod is activated), the program will run a secondary program which will have an incremental counter. The secondary program exits to the main (primary) program which then compares the value to the 75% mark (Actually this could happen in the·secondary program, as well). If the count is => the mark, an LED will light up, signalling a need to change the container with one that is full. Then a button is pressed for that container to reset its counter.
Jon, I did not mean to have appearently ignored you.
I am trying your approach as we speak (err. type?).
I'll let you know how I fare.
POLLing with it set in the latched mode can allow the Stamp to capture brief events, and POLLWAIT 8 can respond very fast to an event on any of the polled pins, but I don't see how that will help you here.
The example I gave above sets up polling on one pin on auxio and one pin on mainio:
AUXIO
POLLIN 8,1 ' poll for 1 on x8
MAINIO
POLLIN 0,1 ' poll for 1 on p0
Tracy Allen
www.emesystems.com
I'll run a looped event with the following structure
While it's in the DO WHILE loop, I know the value of i is incrementing about every (4/12,000) seconds or so. This is because the Stamp can process roughly 12,000 instructions per second (according to the white sheet). Where I get the 3 is because I assume the DO WHILE is one, the increment statement is one, reading in the·pin states in one·and finally the loop is one. This wouold mean I get a rough resolution of 0.3 microseconds. I am only concerned about +/- 2 microseconds, so this should be fine.
I am sure there is a better way, probably using additional components, but to implement them I'll need more help. I am struggling to work in a world of EE's, but my background is ME. I am hip some circuit analysis and some electronics, but this is my first foray into microcontrollers.
I am sure I am missing something and am looking forward to hearing feedback.
Can I store a variable in program 0 to be used in program 1 and have it unchanged when I return to program 0?
I am trying to use Jon's suggestion, but each time I return to prog. 0, "oldstate" get updated with the newstates.
