Model Trains
I want to automate a model train layout.· I·want to install some sensors along the tracks that will sense the trains motion and then switch the track up ahead.· Anyone do this yet?
Dave
Dave
The point of my post is to help direct Dave to the other Model Railroad resources for the detector portion. Look for block detectors, occupancy detectors, etc. Don't worry about what people are doing (or not doing) with them, but there are a number of useful ways folks have come up with the sense when/where a train is. Take the sensor part of these projects, and apply it to your STAMP project.
If you need more pointers on where to find this stuff, let me know and I'll dig some stuff up from home. I'm at work now, and can't get into that now.
John R.
8 + 8 = 10
He's done all of this with a BS2 and a lot of TIP120's. Check it out.
I believe he used IR-emitter-detector pairs to sense train positions.
The shiftregisters will save you ALOT of time wiring up your layout.
If you only have a single train, on a single track loop, then the shift registers won't help you much, but if you have block track layout and multiple engines running on the same layout, you will need to use shiftregisters.
You can use 74HC595's for sending speed, and direction, and turning on various lights, and effects.
This is a parallel OUT, serial IN shift register.
And you can use 74HC597's (or 74HC165's) for detecting things and just getting information back into the stamp from your layout.
This is a parallel IN, serial OUT shift register.
These two chip types will allow you to communicate with your Layout only using 3 or 4 pins coming from your stamp. Shift registers allow one to get really creative with their stamps all while not using up all pinouts from the stamp. (which is eaisly done on an average sized layout, especially if you have BLOCK type layout (the kind that allow multiple trains on the same track path)
Dave
