X-10
hello
I was wondering is it posible to recive X-10 signals through the bs2 WITHOUT
any external objects (eg. firecracker).
thank you.
(though I can build simple circuts)
there are a hundred types of people in the world,
but I dont have time to name them all.
Post Edited (crackticus pots) : 11/28/2005 9:59:30 PM GMT
thank you.
·1+1=10
X10 made two small modules, which plugged in to the wall, to keep the dangerous stuff away from you. I think the TW423 unit would give you a zero crossing signal, and a set of pulses that matched the X10 signals.
The "Home Automation" kit has an RS-232 based messaging protocol "Computer Interface Unit" which should be pretty straightforward to interface to a BS2.
Did you have a look at this, http://www.parallax.com/dl/docs/books/AlJan2000.pdf?
Jim K
the firecracker and the computer x-10 interface from radio shack·uses the same rs232 signals! cool
thanks again.
crackticus pots.
Post Edited (crackticus pots) : 12/1/2005 3:45:08 PM GMT
Your welcome. Glad I could help
Jim K
