Is Boe-Bot + eb500 good solution?
Hello,
can I use Boe-Bot and eb500 transreceiver for this application? I have a serial device, something like joystick, then I want to write an application that transforms data from my device and sends it on USB Bluetooth. Eb500 receives data and Boe-Bot does basic moves. Application could be written in JAVA. Do you have some ideas, sources, that could help me?
Thanks a lot.
Thanks a lot.
I'm sure what you suggest is possible. I have a tracked vehicle controlled via Bluetooth. The GUI is constructed using the excellent StamplotPro software, sending data to a class II Bluetooth adapter in the PC USB port. The data is sent to an Eb500 and BOE BS2. Data can be sent to and from the vehicle using simple serial commands. A wireless camera also is mounted on a pan and tilt mechanism controlled by the GUI with the picture fitting beside the GUI controls on the Stamplot screen.
Stuart
