I purchase some 12v 7.5step Mitsumi stepper motors from parallax and I have been trying to find some wheels that best fit this motor.· Does anybody have any suggestions in which wheels best fit this motor.
I just hot glued two plastic jar lids onto the existing gears.
Epoxy may work better, but I was not sure it would be my final design.
So far nothing has fallen off and if it does I can just hot glue it back in place.
What you do is. ...... ........
You drill an accurate and right sized hole at the center of each lid to position the shaft while gluing.
It really is quite quick and simple.
With either 5 minute epoxy or hot glue you can hold it perpendicular while it sets.
After you have the lids secure, you can use a motorcycle/motor scooter inner tube to make rubber bands for traction.
One inner tube is good for quite a few, so I use the rubber bands for a lot of things [noparse][[/noparse]like holding things in place while gluing and securing the covers to chassis boxes [noparse][[/noparse]without using the screws] when I am working on a project.
Bicycle inner tubes can be handy too for a smaller size. They are get for insulation, dust cover, and securing long wires in bundles.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
