dual row header for wires?
I've been searching hundreds of PDFs from Jameco, Digikey, etc, until my eye's hurt without luck.· I'm trying to find a 20 pin, dual row header·to connect to the appmod connector on a BOE.· The kicker is that·I would like males pins on one side and solder/crimp connectors on the other.· I have a project that uses a 15' DB25 to connect a remote box to a controller box with the BOE.· I could always connect the wires to the connector using a normal header and a PCB, but·I would love to just·connect the wires directly to the header.· I could solder the wires·to the exposed pins, but I'm trying to avoid leaving the connections exposed.· I am also trying to avoid using a ribbon cable between the two boxes for other reasons, so I've ruled that option out.· Any ideas?
Thanks!
Nightrider7731
Thanks!
Nightrider7731
csavage@parallax.com
Have a look:
http://dkc3.digikey.com/PDF/T053/0104.pdf
