Getting accurate frequency with a 555
inaki
I need to generate a·constant square wave of 32768Hz with a maximum error of 50Hz.
I am trying to get that·frequency with a 555.
I get about 32768Hz·at start time·but the frequency changes with time, probably as the components heat, and some time after the frequency is wrong by more than 50Hz which is the maximum allowed error.
Do you think the 555 is suitable for a project like this or should I go straight to a crystal oscillator ?
·1+1=10
1% is 1 out of 100. You need a scope to properly calibrate.
You are calling for 50 out of 32768. Which is .0015 or .15% You have to consider temperature stability as well.
A crystal oscillator without temperature control can easily do it. So can the TTL oscillator.
The TTL oscillator is the simplest because without a scope you can get into trouble with attaching the correct drive circuit, capacitors and resistor to a crystal, but the TTL consumes more power if you already have the drive circuit available.
I have not seen any resonators for that specific frequency. I believe that is a clock crystal frequency, right?
http://ourworld.compuserve.com/homepages/Bill_Bowden/page11.htm
David
fairly expensive, but you can request a sample.
·1+1=10
I was wondering where to get one and for how much as they are 10 times more accurate than the regular crystals.·Timekeeping is about the only place that you need that tight control.
Regular crystals can be easily bought for under $1, but this is $3.75 if you buy a thousand.· Maybe they would send a sample.
Post Edited (Kramer) : 11/29/2005 2:22:41 PM GMT
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Those that would give up freedom for security will have neither.
If 20 to 100 ppm is sufficiently accurate, then I like the Epson SG3030 from Digikey; around a buck, and an operating current of 2 uAmps.
For a slightly higher price Epson also has better than 5 ppm at 5 uA.
Cheers from Maui, Hawaii,
Peter (pjv)
I just looked that part up on digikey, and it's over $20 and you have to buy 25 of them.
Is SD3030 the correct part # ?
Bean.
Your post really shocked me as I was quite sure last year I paid something a bit over a dollar, so the $28 didn't make any sense to me. Looking at the Digikey site, I now find that in singles the price is $3.12. It seems my memory was incorrect. Also there was a listing for $28 and tape and reel proces of $1.48 for 250. Perhaps it was this latter price I was remembering, anyhow sorry for the mis-communication.
I really like the low current as a battery will last a very long time.
Peter (pjv)
