BS1USB backordered!?!?
Buck Rogers
Hello!
I see that the BS1USB is still backordered, until Friday. I can work with that. I won't know until after that if I plan on buying mine. Also I didn't see a place for its documents on the regular documents portion of the main site. Does this mean that its still being developed? No rush, I won't need that until well after my unit(s) get here.
Buck Rogers
www.gregg.levine.name
Buck Rogers
I know I am refering to one of my posts, but I just came from the BS1USB is naturally backordered. However I see it now has its documentation. The file for the BS1USB that of http://www.parallax.com/dl/docs/prod/stamps/BS1USB-v1.0.pdf·won't work. Clicking there produces a complaint from the webserver. And why? Glad you asked. By trimming off the second pdf from the URL, as I did for what I am showing, works. This means that someone probably the web guy who posted those in a hurry will need to correct it.·
Buck Rogers
Here's a link to that document: http://www.parallax.com/dl/docs/prod/stamps/BS1USB-v1.0.pdf
Jon Williams
