problem regarding vdd
i am using pbasic2 ic ie pic16c57c. the ic was working fine and i made a micromouse with it.
But suddenly one day when i started it , the vdd was comming 3.4v and when i removed the basic stamp ic. i get same 5v from the 7805.
And as soon as i attach the ic to the circuit the 7805 starts delivering 3.4v.
what is the problem please help soon?
Jon Williams
what happened?
If your regulator doesn't get hot, then your power supply sounds like its not providing enough, are you providing at least 1.5 volts more than 5 volts? In other words are you providing at least 6.5volts to your voltage regulator? Check all your connections.
does it get hot when you DONT have it hooked up to the serial port?
Do you mean you powered the pic16c57c chip with NOTHING but +5V and GND connected and it gets hot/draws too much current?
That again sounds like your circuit wiring is bad, something in your circuit caused the pic16c57c to fry.
Ive had different kinds of IC chips fry on me, and when they do, they either don't work and don't heat up, or they heat up like mad and still don't work. Some smoke, some work for a while at seriously hot temperatures and then Smile out, some just die without a wimper.
Almost all IC's will NOT get hot if they are wired and working properly.
A good method of electronic design is the finger test. TAP your chip with your finger as soon as you power it, keep tapping it to see if it gets hot, if it starts to feel warm or hot, then quickly turn it off, because something is wrong.
I have had that method save my IC's many times. Its not GOOD for your IC's but at least it still might work after you fix the wiring problem.
It kinda sounds to me like you fried your pic16c57c. If you can't even provide 5v and GND without it getting hot, while its not connected to anything, then its most def fried. (im talking power the pic16c57c ALONE, no EEPROM, nothing)
Most IC's will just SIT there when you connect GND and 5V. They shouldnt get hot, or even warm.
Before you go out and replace it, you need to go over your circuit and figure out why it fried. Because you will just fry another.
Post Edited (BPM) : 11/27/2005 5:09:19 PM GMT
