Anyone with schematics and code for using the adc0838 8 channel with the stamp?
Hey parallax group. I am using the 8 channel mux adc0838, but do not know what to do with all the pins. What are the use of the v+, comm, agnd, dgnd, and vref used for? I just want to use singled ended mode and have several 5v sensor I would like to connect to different channels.
·· The schematics should be almost identical to the ADC0831, with the exception of the extra channels.· Generally speaking the datasheet has example connection diagrams, although I haven't checked this one in particular.· In fact, if memory serves, I think the ADC0831/0834/0838 all use the same datasheet.· Parallax has several examples of using the ADC0831 and ADC0834 which should provide you with an adequate example.
csavage@parallax.com
http://www.parallax.com/dl/docs/prod/sic/ExpRenewNRG1_0.pdf
and
http://www.parallax.com/dl/docs/prod/sic/ExpRenewNRGErrata.pdf
I hope this helps you...
SE -- Select Enable, it's an input
All this & more on the attached Data Sheet (it's labelled ADC0831etal.pdf -- and you'll find that the 0838 is included in detail.)
When you get 1st Place in the "Darwin Awards", you're a Winner & a Loser.
