SX28 with USB port !!!
Filipe
Hello all people,
Any one have experince with USB for SX28 ?
I think is a good ideia to connect other new devices like Bluetooth, etc, etc.
Many thanks from Portugal;
Labtronix
Labtronix
Jon Williams
http://www.ghielectronics.com/USBwiz.htm
I am currently writing a class for the Javelin using its Uart interface.
SPI and I2C are also supported.
Keyboard, mouse, network and storage devices are supported by the usbwiz.
An oem board is available.
regards peter
Jon Williams
I am thinking that it might allow the SX28 to drive a robot either directly or via a link [noparse][[/noparse]IR or RF].
If so, it really is quite appealing.
I hope it allows communication between two usb lan adapters connected
to two usbwiz oem boards. I believe (some) usb lan adapters can act as an access point
(so in effect you would have a wireless crosscable network connection).
regards peter
There is also this page at SxList.com:
www.sxlist.com/techref/usbs.htm
Thanks, PeterM
Anyway, I do know that Parallax sells USB IC's for a lot cheaper than a module. Anyone have experience with these? Anybody want to post a project?
In my particular case, I want to make a stand-alone USB box (no computer) that interfaces with a simple HID device. The unit would just have to receive a couple of switches on/off states and only send a few packets of info. Speed is not an issue. It would also have to be as cheap as possible, therefore the IC's look better than a module (even a cheap module).
Jon Williams
The USBwiz device looks cool and would be perfect for me, except the cost.
Any one use this device?: SL811HS
Yeah, it would take a lot more programming, but 1/3rd the cost of the wiz.
The Cypress is designed for the type of application your looking at, micro-to-micro. This is how pictbridge works without using a PC host. While it may take additional code the end result would work very nicely. If your doing real USB development, Cypress really does it right. Their USB devices typically allow you to code your entire USB interface within the chip allowing you to use the micro as the workhorse of the system as it was intended. So adding this part to the Sx should require minimal code on the SX and allow the SX to be both a host and slave device.
Oliver
Filipe
