vcc?
Hello,hello. I'm pretty new in this universe and I'm just wondering what vcc is? Is it the same as vdd? I'm assuming it wouldn't be labled differently if it was but anyway any help would be great.
Post Edited By Moderator (Chris Savage (Parallax)) : 11/24/2005 6:14:30 AM GMT
Would you believe yes? It took me a lot of work to realize that they are indeed the same thing. They just refer to two seperate but related forms of logic. Vcc happens to be for TTL logic. Vdd is typically for CMOS logic. Sometimes the families happen to be running under the same voltage levels, and in this case don't worry.
But things get crazy when you need to connect circuit elements that are based around those two different families, and the CMOS one happens to be running around a different level, say the Vdd is at 3-15 volts, and the TTL one happens to be Vcc at 5volts or so, which is normal. The companies that I buy compnents from, sell hardware which can handle translations between those.
And did I mention this is also supposed to be fun?
Buck Rogers
www.gregg.levine.name
···· VDD ·= + PART SUPPLY
···· VEE·· = - PART SUPPLY
·····VSS· =·· GROUND
Short
Vcc = Vcollector
Vee = Vemitter
Vdd =Vdrain
Vss = Vsource
If you think of normal chip outputs, Vcc and Vdd are generally +, and Vee and Vss are generally - (unless you're in ECL or something equally oddball), it just depends on if it's an old TTL or a newer CMOS part. They're used interchangably a lot now, which annoys some of us who know the difference.
-dave
This is not a sig. This is a duck. Quack.
They may be useful terms to describe the chip internals, but for interfacing by the average public, wouldn't +5 and gnd be better?
David
Maybe you could remember that "VSS" stands for "Voltage Stepping Stone" and Stepping Stones are usually on the ground.
lol
cbmeeks
http://metroidclassic.com
DMCA Sucks
RIAA Sucks
DC belong together as in AC or DC voltage. So they are the same
S can be considered 'soil' or 'safe'. Both associate with ground.
I still remember ROY G. BIV for the spectrum from high school [noparse][[/noparse]1965].
