PINK update problem
Hello,
I have set up the PINK module with the BS2, it has an IP address assigned and access is available to the nb_factory web page.
But the variables on the module NBvar00, etc. are not getting updated when the stamp communicates with the PINK module.
I have set a baud rate of 2400 on the PINK settings page, and 396 in the stamp code.
I have used telnet to see if there is any communication, and it does show the traffic.
An oscilloscope on the RX and TX pins shows some activity when the stamp and PINK communicate too.
I am using code provided on the PArallax website, as well as others provided on the discussion forum.
But the code provided by Tracy Allen with the "timeout error" for SERIN, it always goes to "timeout error", i.e, nothing is being received from the PINK
I would appreciate any suggestions to figure out the problem as to why the variables on the PINK do not change.
-Nikhil
-Nikhil
-Nikhil Vora·
