Need For Speed
Hi All,
I just discovered the Basic Stamps. Great stuff.
I have a project in mind and I wonder if the Stamps can help me. I want to rotate a mirror (10 x 10 cm / 4 x 4") around an axis. The mirror should move about 15 degrees, then·a contact is closed and after a respons·the next move of 15 degrees begins. This·seems very·simple, but I want to do this five times a second :-).
So the mirror should move 15 degrees in 0.1 second and be motionless for the next 0.1 second before it moves again.
The standard servo seems to slow (1.5 sec for 180 degrees) but the mini servo might do it (0.5 sec for 180 degrees). The mirror will be able to move very light, so it's only a matter of starting and stopping the mass of the mirror.
I wonder if this will work, taking into account the processing time of the Stamp. Can anyone·hint on·what Stamp and motor I should use? I was planning to go with the USB Education board.
Any input very much appreciated.
Jon Williams
I much appreciate your help.
So If I would purchase the USB "Basic Stamp Discovery Kit":
http://www.parallax.com/detail.asp?product_id=27807
and two stepper motors:
http://www.parallax.com/detail.asp?product_id=27964
then it would basically work? Or do I need an additional "Motor Controller"? I want to use two motors to rotate around X- and Y-axis but only move one at a time.
Sorry for maybe asking the obvious but I'm totally new to this (except for Lego Robotics and Visual Basic).
Philip
Jon Williams
I'll go with the ULN2803 and the two unipolar stepper motors. If I search the Parallax site for ULN2803 I find the "ULN2803A Darlington Array" and I suppose that is what you mean. The pdf on the page seems to indicate in this direction
Thanks for your help!
Jon Williams
