Question about Debug command
This is probably a simple question but it's one I haven't encountered before. Does the debug window open when it hits the Debug command in your program or does it open anytime there is a Debug command anywhere in the program. I'm having some trouble with a program and I was expecting the debug not to open if the program hadn't reached the command but maybe I was wrong. Thanks.
Lee Harker
Lee Harker
debug cr
as the first line of yiur program.· Since I like to control when my programs start I usually write the following at the very beginning of my programs:
debug "Press any key to start", cr
debugin com
Sid Weaver
Do you have a Stamp Tester yet?
When you compile and run your program, the Basic Stamp IDE automatically opens the debug window for you since it "sees" that the DEBUG command is used somewhere within the program. Here is another example, download a program which uses the DEBUG command, then shutoff the Stamp and close the debug window. Turn the Stamp back on and you will find that the debug window does not automatically open. You have to manually open the debug window yourself and select the COM port the Stamp is connected to.
Alan
"I learn when I succeed, but I learn more when I fail."
Thanks for the confirmation. I suspected that's what happens but I needed a second opinion.
Lee
