Pink help
I just purchased the PINK module and I am having a difficult time getting my Basic Stamp 2P-24 to communicate with the PINK module.· I tried using the simple programs to read and write the regisiters in the pink module.· Any suggestions?· Thanks, John
csavage@parallax.com
Can you get to the nb_factory.htm page? (Use the IP of the module/nb_factory.htm)-
For example:
XX.XX.XX.XX/nb_factory.htm
Ryan
Ryan Clarke
RClarke@Parallax.com
Thanks for your help and everyone else's suggestions.· I figured the problem out.· It was the BS2p I am using, I can only use 1200 baud to communicate with the PINK module.
Ryan
Ryan Clarke
Are you using any of the SERIN input formatters (WAIT for example). I believe the BS2 series sometimes has trouble synchronizing themseleves with baud rates over 2400 bps when input formatters are used.
On-the-other-hand, it might be possible that the BS2p is missing the serial output from the PINK (such as a SEROUT request for a PINK variable and then SERIN). I was thinking a small momentary pause between the SEROUT and SERIN statements may help.
These were just a couple of ideas I had and, if I get the chance, I may try it out in my setup.
If you have the chance, I would upload the source code so that we could see what it is doing.
Alan
"I learn when I succeed, but I learn more when I fail."
