Is this possible with the Bs2?
I have a mini-satellite airborne, with a Bs2 and various sensors transmitting data via RF to a ground station PC. However, we will be launching our satellite in remote locations without power, and I dont want to lug around ( much less purchase) 12v batteries and/or inverters as I have seen others do in such situations. So it would be wonderful if the PC ( as the ground station data collection and satellite interface) could be removed from the equation ....
So I was looking at Alex Hunts project (GPS Rocket Locater) and had this thought:
Bs2 in the airborne satellite collecting and transmitting data via RF to a ground unit consisting of a recieving RF module, a second bs2, some EEPROM and a LCD mounted perhaps in a project box and powered by a 9v battery. Or even have all the ground station components mounted and running from a BOE in the project box( appmod header could be used for a parallax LCD?). Print the data collected from the airborne satellite to the LCD, log the data to the EEPROM for later collection via a db9 connector and a computer when power is available for a PC at another location, and possibly using stampdaq to log the data on the PC.
Just wondering if anyone can tell me if this is doable, not really looking for solutions atm - but dont want to propose a impossible idea to the Profs in charge hehe
if you do respond, can you also please mention( in your opinioin) what level of complexity this project sounds like? ( the ground unit portion) ie, easy, moderate, hard , impossible...
Thanks and alohas for your responses!
Robert
Robert
You don't want to "brown out" your battery with too much draw.
Start adding up the power specs on all your devices!
Steve
For the log time - actual flight time is about 10-15 minutes, probably be logging data for perhaps 5-8 minutes out of that.
Post Edited (Robert@HCC) : 11/22/2005 12:54:24 AM GMT
