Pwmpal — Parallax Forums
Pwmpal
SAMMYSAMMY Posts: 9
edited 2005-11-22 21:55 in Robotics
·can anyone give me some more detailed info on the pwmpal, ex. What voltage motors?,etc.
    edited 2005-11-21 21:42
    The PWMPAL has TTL level outputs; you can drive any motor you choose with properly selected driver components. Just to be clear, the PWMPAL is not capable of providing enough current to drive motors directly, you'll need to use some sort of transistor buffer.
    Jon Williams
  • TiboTibo Posts: 81
    If your need is to power a rolling robot, then you might consider an H-Bridge circuit, so you can control direction and speed of the wheels, and a PWMPAL.
