SMT Component Source
One more question. Where can I·buy Surface mount components in low volume. I need a 555 IC, some resistors, capacitors, a multiturn resistor, led's (red and infrared)·and a·miniature·switch and I only need a few (maby 5) of each. They dont absolutely have to be surface mount, but I would prefer that they were. I may use regular LEDs if I cant find surface mount ones large enough (about 5mm)·Im trying to learn how to make Surface mount components and want to make my own PCBs so I would like to do as little drilling as possible. And I am guessing it would be best to start out with the larger .120" sized stuff and work my way down to smaller parts.
jameco.com
digikey.com
newark.com
also its easier to find somer parts using findchips.com
they compare prices between vendors
DTQ
http://www.danssmallpartsandkits.net/
I wonder if this wire is hot...
