bs2 program help
I would like to know is there anyone could help me with the following program
This program is supposed to simulate a model elevator. Where when an input from pin3 is detected it counts the floors while output on pin9 and pin10 is supposed to turn on and off the motor as the shaft on the motor passes through a interupter that detected from pin3.
' {$STAMP BS2} ' {$PBASIC 2.5} cf VAR Byte df VAR Byte cf = 0 df = 0 Start: DEBUG CLS DEBUG DEC cf DEBUG "Current Floor = ",cf ,CR DEBUG "Enter Destination",CR DEBUGIN NUM df IF df > cf AND df <=9 THEN GOTO Up IF df < cf AND df >=0 THEN GOTO Down IF df = cf THEN GOTO Start Up: DEBUG "Elevator ascending", CR DO cf = cf+1 PAUSE(1000) HIGH 10 LOW 9 DEBUG "Current Floor is ", DEC cf ,CR LOOP UNTIL df = cf PAUSE (500) GOTO Start Down: DEBUG "Elevator Descending" ,CR DO cf = cf-1 PAUSE(1000) IF NOT IN3 = 1 THEN EXIT HIGH 9 LOW 10 DEBUG "Current Floor is ", DEC cf ,CR LOOP UNTIL df = cf PAUSE (500) GOTO Start END
Jon Williams
sorry for the delay.
You should also limit the number os levels the elevator can reach...
Post Edited (Tibot) : 11/26/2005 8:00:07 PM GMT
cf = cf+1
PAUSE(1000)
HIGH 10
LOW 9
LOOP UNTIL df = cf
PAUSE (500)
GOTO Start
It looks like that part would just turn the motor on, cycle through the code, and head on back to start without actually looking at the elevator itself, leaving the elevator on.
I think it is the
IF NOT IN3=1 THEN EXIT
if not LOW on PIN N°3 then EXIT
similar to
if IN3=0 THEN EXIT
It means at this step, the Basic Stamp is looking at the PIN n°3 state.
If it is high, then EXIT the loop.
