Digital power supply
I don't know if anyone has done this, but I'm trying to make a dual digital power supply. The power supply needs to have outputs from 3-20V and anywhere from 1-5A. I know that there are two Nuts & Volts articles that touch on this, but the design presented had limitations. Those limitations being it only had a range of 3-10V and output 1A. A plus for the power supply would be to measure current draw and to be able to limit the current draw to a specific amount (i.e. 750mA). Any thoughts as to assistance on this would be appreciated as I'm not the most experienced electronics hobbyist and would like to build this for use in my semi-existant lab.
Truth can be dangerous... Trust can be deadly.
If you need an output of less than +1.25V, you can reference the adjust circuit to -1.25V, instead of to circuit Ground, and that'll give you adjustability all the way down to 0V.
P.S. I've included a picture of the example circuit provided in the datasheet for reference.
Unless I totally misinterpreted the data sheet....
Now what I'm wondering, is if there is a digital potentiometer out there that would have better resolution?
I've looked on a couple different manufacturers' sites and couldn't find any that might fit. Though upon reading further,
it seems that the max resistance used in the DS1267 is around 5k (not sure if this is correct or not). So I figured that if I could find a digital pot that only
went to 5k ohms and had the same number of steps (256), that the resolution would be better. But looking on the sites (again),
I found that it seems that 10k ohms is the lowest digital pot made.
A better precision potentiometer will not solve your problem, and that is heat.
In order for your supply to provide the 20 V out you need, then the input to the regulator needs a voltage around 23 volts or higher. And it had better be a beefy source to be able to deal with that 5 Amps you stated.....lots of concern over ripple at that current.
Then, when your wish is to have the unit set to a low output yet high current, 3 Volts at 5 Amps, the thing must dissipate 20 Volts (23 Volts in minus 3 Volts out) at 5 Amps, and that's a nice tidy 100 watts. No way you're going to do that with ANY integrated circuit regulator, regardless of the precision of your resistors!
What you need for those ratings is a switcher, or something that will lower the input voltage when you wish a low output voltage. Look at the device dissipation ratings; probably the best is 25 watts with a GOOD heatsink and blower.
For what you're looking for (your ratings) from an IC regulator, you are on the wrong track.
Cheers,
Peter (pjv)
I guess that with that little bit of information, I'll stay on track with using the MAX726 instead of the LM317 or the LM1084.
I am new to all of this so I have to go by what people say or what is written in the Nuts & Volts articles.
The formula for heat (watts) is the voltage drop (Vin minus Vout) times the current passed. So in my example from your requirements, (23 V in - 3 V out)·times 5Amps is 20 * 5 = 100 watts.....quite a bit of heat. (Ever put your hand on a 100 Watt light bulb?)
I encourage you to keep reading and then experimenting on circuitry about what you have read in order to gain a full appreciation of the words. For me, words alone don't seem to complete the understanding process; the experimentation really helps nail it.
Do expect to smoke some components, but that is normal.
Above all, have FUN.
Cheers,
Peter (pjv)
Post Edited (pjv) : 11/20/2005 4:27:55 PM GMT
My very old variable power supply needs to be retired. I've been looking at the LM317/337 datasheets and application notes the last month or so.·- What applies to these would probably apply to other regulators.
I found the applications quite a lot of fun and the LM117/317/337 are simple enough for me to understand what's going on.
Whatever you choose, have fun... and let us know how things work out.
Kind regards from Kwa Dukuza
John Bond
