Reading list for Assembly — Parallax Forums
LoopyBytelooseLoopyByteloose Posts: 12,537
edited 2005-11-20 07:45 in General Discussion
I am sitting here trying to create FIFO buffers for an RS-232 port on an SX-28.
While it is a wonderfully create process to DIY, I am beginning to wonder if I should have a better library.
I have seen a text called, The Art of Programming and wonder if it is at all as good The Art of Electronics.· Also, I wonder if there is a classic algorythm 'bible' that provides you will options and explanations in a practical sense.
While Parallax works very hard to publish supporting material, I am sure there are titles with broader overview·that come to mind and should be mentioned.
  • Guenther DaubachGuenther Daubach Posts: 1,321
    edited 2005-11-19 13:20
    Did you see the FIFO code in my book - there may be better implementations that this, but it works.
    Greetings from Germany,
    G
    edited 2005-11-19 14:39
    I've done two projects that use buffered serial receive in SX/B -- here are the links the the N&V articles:
    http://www.parallax.com/dl/docs/cols/nv/vol6/col/nv117.pdf
    http://www.parallax.com/dl/docs/cols/nv/vol6/col/nv122.pdf
    Jon Williams
    edited 2005-11-19 15:06
    Thanks guys,
    I certainly have seen G
  • RsadeikaRsadeika Posts: 3,901
    edited 2005-11-19 15:08
    Are you referring to The Art of Programming, the three volume set. If so, that is a book that deals primarily with assembly language; looking at the table of contents, I did not get the feel that it could be used for a·better understanding of SX programming. I believe the set of books is for people that are into the PC side of things.
    edited 2005-11-19 17:36
    Kramer,
    My I suggest that you may be worrying unnecessarily. Even if you do reinvent a wheel or two, you'll understand that wheel and will be better for the process. Just a thought.
    Jon Williams
    I see. It is quite a reading load. I suppose enthusiam just got the better of me.
