Connecting a printer to Basic Stamp
Hi Fellas,
I'm getting involved with a datalogging project where I need to get a hard copy after the test is complete (using Basic Stamps).·
Wondering how to connect a printer (any type of printer) to a Stamp.· I am sure there must be an intermediate device (USB) that is available to connect to a Stamp somehow, then you connect the printer to the USB device?· Or can you use a straight serial printer.
I am also guessing that you can use SEROUT command to output data to the printer.· I'm sure it gets wildly complex, but any help of what type of equipment I need and frags of code to get me started, would be much appreciated!
Thanks - Brian
Thanks - Brian
Sid Weaver
Do you have a Stamp Tester yet?
Formatting wasn't too bad, as everything was monospaced, so you just needed to keep track of line position, and figure out how many spaces between fields (taking into account a possibly variable field length). The printer I worked with used separate carriage return and line feed characters.
If you can find a serial dot matrix, you should be all set.
John R.
8 + 8 = 10
John R.
8 + 8 = 10
RoboGeek
There are·3 kinds of people in the world,
the dreamers, the do-ers, and the "Oh, what's this button do"-ers.
Formerly bugg.
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.startrek.com
Post Edited (RoboGeek) : 11/19/2005 1:24:33 AM GMT
73
spence
k4kep
73
spence
k4kep
http://www.parallax.com/dl/docs/prod/book/bs2pCommnFeat.pdf
1. Use a somewhat traditional serial printer
2. Use an I2C chip to get either parallel or serial I/O
[noparse][[/noparse]I am assuming USB printer requires too much initializing code for the BasicStamp to have much space left for an actual task.]
Option One, you may need hardware control lines as well as the Rx and Tx. To do so, I think you need to establish an other serial port with TTL signals and covert them the RS-232. I suppose you might try to use the existng port [noparse][[/noparse]the signals are already inverted] and just add two lines, but you might fine it just ain't worth it unless you absolutely must save two pins.
Lately, I have been thinking that USB is fairly limited in the embedded system environment. It seems to allow transmission and reception, but is very limited on control. Traditional RS-232 had 9 lines - one for the Ring Indication [noparse][[/noparse]nearly useless], four for Tx, Rx, and related grounds, and four for handshaking. Printers like to handshake.
www.phanderson.com/stamp/i2c/print1.html
Knight.
This message transmitted with 100% recycled electrons.
Gravity doesn't exist. The Earth sucks.
Make a man a fire, and he will be warm for the night.
Light the man on fire, and he will be warm for the rest of his life.
