ZIF Socket for SX48?
I've chosen the SX48 for the microcontroller·for many of our products that require a microcontroller and would like to know if there is a ZIF socket available for the 48P TQFP package in order to program the devices before they are placed on the board. On the prototypes I have a header to program the chips but for the final designs I’d like to stay away from this for EMI reasons.
-Dan-
-Dan-
Shouldn't be an issue if you are in production since it's cost will be ammortized over the entire production line using the chip.
Seems most of the programming adapters use the Enplas line of sockets: http://www.enplas.co.jp/english/business/espc/test_burnin/pdf/catalog013.pdf
be sure you aquire the right type, part FPQ-48-0.5-06 is an example of a suitable socket (also the most expensive since it is thier clamshell variety (ZIF), OTQ-48-0.5 (03 or 10 suffix) would also work but is not ZIF (1.7 kg max actuation force)
Thier american branch office is in Sunnyvale, CA, website is here: http://www.enplas-ets.com/
·1+1=10
Post Edited (Paul Baker) : 11/18/2005 7:46:35 PM GMT
Though thier price is just as expensive as the socket, though I found·Agilent E2614A 0.5 Wedge clips for $39 here: http://used-line.com/b2545p1pr2-Used-leads.htm
Which may be your best bet if it is a low quantity production.
·1+1=10
Thanks for your help.
-Dan-
